Old Jul 22, 2015, 1:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
1995 Tahoe tail light assembly
Old Jan 12, 2007 | 2:42 AM
sfechter's Avatar
Default 1995 Tahoe tail light assembly
I need to replace a rear tail light in my wife's 95 Tahoe.
I cannot see how to remove the assembly as there are no visible screws or clips. Any suggestions?
Old Jan 12, 2007 | 3:55 AM
engine2's Avatar
Default RE: 1995 Tahoe tail light assembly
I am not familiar with the taillight assembly of your particular model year vehicle, but I am going to take a stab at it anyway. In your other post you mentioned you just needed to replace a burned out bulb. You might be able to reach the wire / connector going into the back of the rear lamp assembly. If you can, you might be able to just twist the connector the bulb is in and pull it out. I hope this helps. I sure other's here more knowledgable will throw in their 2cents. Good Luck
Old Jan 12, 2007 | 11:20 AM
lost_in_alabama's Avatar
Look inside the door frame. There should be one screw holding the taillight assembly.
Pooterosa
Jan 25, 2015 9:45 AM
beckya99
Jul 12, 2011 12:29 PM
JDR0618
Apr 10, 2011 9:30 PM
1LooseLugNut
Aug 15, 2010 6:46 PM
sfechter
Jan 12, 2007 3:50 AM
