1996 suburban ls rear a/c not getting cold
Old Jul 21, 2010 | 9:55 PM
claudeezy80's Avatar
Default 1996 suburban ls rear a/c not getting cold
Hey everybody, thanks for having me!
I have a 96 suburban ls and i was having problems with my a/c... I found what the problem was and fixed it (so i thought)... I replaced the a/c compressor, i "fixed" the ac line that had a crease/crack in it with some jb/weld and a 2nd layer of pc-11 plumbers putty (works wonders!!! Lol). Ok on a serious note, the front a/c works great now but the rear a/c won't get cold... And i can't figure out what the problem is. Someone suggested that the rear a/c has its own a/c fittings somewhere in the rear of the suv. Is their any truth to that or could someone give me an idea of what else could be the cause of that...
Thanks for your time weather you can or can't help, i really appreciate it!!!
Old Jul 22, 2010 | 12:12 AM
Welcome to the forum.
There is a second evap. for the rear A/C unit so there will be lines running back to it. Not sure where it's at on yours but probably in front of the psgr side rear wheel.
If the crack you repaired w/ JB weld was leaking, you might as well be prepared to replace that line.
Old Jul 22, 2010 | 8:00 AM
jdubg23's Avatar
prolly need more refrigerant... i think the rear evap is the first to go if the refrig runs low...
Old Jul 22, 2010 | 10:17 PM
thank you both, i'm gonna try both repairs and see what i get, i'll get back to you in about a day or 2 to let you know how i make out...
cowboykeg11
17
Apr 19, 2014 3:20 AM
mdec950
May 11, 2012 9:44 PM
boneskeys
Jul 26, 2011 4:29 AM
rickyracer
Sep 7, 2008 11:56 AM
1981camaroz28
Oct 28, 2007 6:45 PM
