1996 Tahoe - ABS Light
Old Aug 21, 2010 | 5:49 PM
DNIC75's Avatar
Default 1996 Tahoe - ABS Light
1996 Chevy Tahoe - 143,000 miles. 4x4
ABS Light is staying on constantly on the dashboard. I connected my OBD II and got no codes.
Any ideas what this could be? Showing no other signs / symptoms.
Thanks
Old Aug 28, 2010 | 10:04 PM
DNIC75's Avatar
Any input?
Thanks
Old Jan 13, 2011 | 7:07 AM
inthechateau's Avatar
Default ABS light on 96 tahoe
Any luck yet with your ABS problem? I have same issue with my 96 Hoe. Need to fine a reader that can pull the ABS codes. i think my module failed as the pump will not kick in during a tire slide anymore. Brakes still work peoperly just don't have anitskid.
Old Jan 13, 2011 | 8:12 AM
RacerX's Avatar
what kind of code scanner do you have? the cheaper ones wont tell you body codes only engine ones.
Kerry Doran
Sep 18, 2016 6:23 PM
Newto4x4
May 9, 2013 1:34 PM
Charlie3
Jun 23, 2010 7:47 PM
Deteoni
Mar 28, 2009 1:39 PM
