1996 Tahoe AC problems
:cool:I recently purchased this 1996 Tahoe. Its ac cycles on for 3 seconds and off for 10 seconds. At first it blew only hot air so I put a can of Freon in and it started cooling. The following day it would not cool again. I put a set of gages on and the low side pressure varied from 10-70 psi as it cycled. The high side pressure reads about 35 psi and when I press down on the red high pressure coupler the pressure reads a variance of 100-150 psi as it cycles. Can anyone help with advice or guidance on how I might proceed with repairing this AC problem.
Ok, the official performance test:
1.) Park inside garage or shaded area.
2.) Take note of Temp and Humidity
3.) Hook up High & Low pressure gauge to A/C under the hood
4.) Close all doors and windows.
5.) For rear A/C option turn rear A/C on
6.) Turn on main A/C set temp to full Cold and blower to High
7.) Open all of the A/C vents
8.) Place Thermometer in right center vent
9.) Stabilize engine speed at 2000 RPM in Park
10.) Run the A/C for At-least 3 minutes
11.) Record the A/C temp and Low and High Pressures.
Data for 100 Degrees and 30~40% humidity engine @ 2,000 RPM
Low Pressure: 31~37 PSI MAX
High Pressure: 328~361 PSI MAX
A/C Outlet Temp: 53~59 degrees MAX
Ok I did the test.
Temp 100
Humidity 41
AC temp in degrees at vent after 3 min @ 2000rpm = 100
Low pressure reading cycling variation 15-47 psi
High pressure reading 50 psi but if I hold downward pressure on coupling the pressure varies by cycling at 60-110 psi
Temp 100
Humidity 41
The specs for the 1996 model vs the 2007 model differ great while still using R134A. My burb calls for much lower pressure readings vs the 96. This data was pulled from All Data A/C Performance Test using: 1996 K 1500 Suburban 4WD 5.7L
Ok after doing the test and discovering the following readings, what does this tell us I should do next to get the AC working again?
Temp 100
Humidity 41
Temp 100
Humidity 41
RwChevy967
July 11th, 2013 10:56 AM
jheddlesten
September 17th, 2007 5:49 PM
