1996 Tahoe AC problems
Old Jul 10, 2013 | 2:11 PM
RwChevy967's Avatar
Question 1996 Tahoe AC problems
I recently purchased this 1996 Tahoe. Its ac cycles on for 3 seconds and off for 10 seconds. At first it blew only hot air so I put a can of Freon in and it started cooling. The following day it would not cool again. I put a set of gages on and the low side pressure varied from 10-70 psi as it cycled. The high side pressure reads about 35 psi and when I press down on the red high pressure coupler the pressure reads a variance of 100-150 psi as it cycles. Can anyone help with advice or guidance on how I might proceed with repairing this AC problem.
Old Jul 11, 2013 | 7:16 AM
ebacon's Avatar
Possibly the high pressure cut off switch needs replacing. If that dosent do it I would suggest a new compressor, dryer, condenser and a evap flush as there is prob metal in system. Make sure you replace oriface tube in line under battery as well. This will also contain trapped debris. You can buy diffrent tubes than the oem that will help it blow a little colder
Old Jul 11, 2013 | 10:56 AM
RwChevy967's Avatar
Thank you for the helpful response.
RwChevy967
Jul 12, 2013 3:58 PM
chevygurl03_03
Nov 3, 2009 9:33 AM
bigbob
May 8, 2008 9:25 AM
joshuaboudreauxksig
May 4, 2008 4:06 PM
jheddlesten
Sep 17, 2007 5:49 PM
