1997 K1500 Front end noise
Old April 3rd, 2008 | 4:51 PM
BJ1125's Avatar
Default 1997 K1500 Front end noise
I have a noise I think in the front end while in 2wd. It sounds like wobbling/rattling. I can't tell if its from one side or the other. The front end will engage when I put it in4WD LO - 4WD high will not engage. The sound is not constant, it comes and goes.The sound is more noticable at 30-50 mph - it does not change if I change gears (OD, 3, 2 and even neutral) or turn either way. The sound does not get louder as speed increases nor does it quiet as speed decreases until you get below 20 MPH then the sound is gone. I thought itmight bethe T-case or Front Axel trying to engage partially. I removed the fuses for these items and the noise was still there. Any ideas?
Old April 3rd, 2008 | 7:28 PM
ZX1100F1's Avatar
Default RE: 1997 K1500 Front end noise
Does lightly applying the brakes make it stop?
Old April 4th, 2008 | 3:38 PM
BJ1125's Avatar
No, I've tried light pressure and heavy pressure while going straight and turning. Going over bumps or rough roads doesn't change the noise either.
Matt_pound
May 21st, 2013 10:40 PM
Serpent
May 4th, 2013 9:02 PM
RRR
June 17th, 2012 6:42 AM
TASpinney9110
March 15th, 2011 5:54 PM
02TrailBlazer
March 14th, 2006 2:28 AM
Quick Reply: 1997 K1500 Front end noise
