1997 Suburban Engine part identification
Old Nov 8, 2020 | 9:02 PM
trund's Avatar
Default 1997 Suburban Engine part identification
Hi Guys,
I have a 1997 Suburban that I would like to start doing small repairs on. When examining the engine, on the driver's side, I saw the item circled in yellow in the center of both attached photos (regular and close-up). It seems to be screwed into the engine, with a boot on the other side.
Old Nov 8, 2020 | 10:01 PM
Rednucleus's Avatar
I believe that's the coolant sensor for the dash gauge, vs the one on top by thermostat that talks to the computer
Old Nov 9, 2020 | 2:14 PM
PNW NBS Z71's Avatar
That is in fact the coolant temp sender for the gauge. As @Rednucleus said, the one at the top of engine at the intake manifold close to the thermostat housing, is the sensor for the computer.
Old Nov 12, 2020 | 9:46 PM
trund's Avatar
Default 1997 Suburban engine part identification
Thanks, rednucleus and PNW NBS Z71 . So, if my 97 Suburban starts up quick when cold, but takes longer to start when warmed up, which one of these two sensors might be causing the problem?
Old Nov 12, 2020 | 11:02 PM
Rednucleus's Avatar
The circled one only runs your gauge and has no effect on engine performance
Old Nov 13, 2020 | 8:04 AM
repairman54's Avatar
Your symptom is one of a possible leaky injector. Cold motor likes extra fuel, hot motor not so much. Try stepping on the gas pedal when hot starting and see if it improves. If so run a couple tanks of a good injector cleaner like Techron or one with PEA in it and see if it helps.
I had to change the spider injector setup in my old '99 Yukon for a leaky injector.
Old Nov 13, 2020 | 8:09 AM
What @Rednucleus just said. But, that sensor may not be the actual cause of the warm start problem but would be a very inexpensive attempt to fix. This one is at RA for $31: https://www.rockauto.com/en/moreinfo...03063&jsn=2584.
It is the OE one. You can get less expensive aftermarket ones and even $10 less AC Delco one but I always defer to OE if available.
These engines also had problems with the fuel injection systems, SPIDERS, over the years.
fivemobbs
Jun 28, 2020 8:33 PM
BobShelton
Apr 13, 2018 4:03 PM
lromero
Aug 13, 2007 2:48 PM
bauschone
Apr 24, 2007 12:45 AM
bauschone
Apr 24, 2007 12:43 AM
