1998 suburban power window problems
Old Dec 22, 2007 | 5:28 PM
fiteit's Avatar
Default 1998 suburban power window problems
Pwr windows won't work, checked breaker (ok), no pwr to fuse box. What preceeds the fuse box that I could be losing power?
Old Dec 22, 2007 | 6:27 PM
EvansBlue's Avatar
Default RE: 1998 suburban power window problems
Do you have a power window relay?
Old Dec 23, 2007 | 3:30 AM
fiteit's Avatar
I'm not sure if it has a relay. I haven't gotten a manual yet. Is there anyone that knows and where I might find it if it does?
Old Dec 23, 2007 | 9:23 AM
EvansBlue's Avatar
The realay should be in the fusebox under the hood.
Old Dec 27, 2007 | 11:20 AM
fiteit's Avatar
No relay, the wiring diagram shows power into the fuse box but not where it originates from. The fuse was good but I check for power at the fuse spade and no power is going to it. Does anyone know were the power originates from that goes to the fuse box for the power windows?
Old Jan 12, 2008 | 2:50 PM
fiteit's Avatar
I checked for the relay in the engine compartment and with all the fuses it has no relay for the power windows. Is it possible that the power goes through the window switch first and then through the fuse?
justin69
Feb 28, 2015 2:54 PM
arktrans
Jun 29, 2011 12:06 AM
davbell22602
Mar 10, 2010 8:36 PM
lmiskowicz
Nov 21, 2007 9:02 AM
