1998 Suburban starting problem
Old Jul 2, 2014 | 10:54 PM
  #11
calwaterbear's Avatar
Originally Posted by burban98
I have a 98 burban, it was running fine until today, when I go to start it, it clicks.... the battery seems fine everything is connected nothing has been left on to kill the battery as far as I can tell..... any suggestions
Most likely the battery! so:
charge the battery, even though inside lights and other stuff might work, the battery may be giving up. or put it on jumper cables, and see if that fixes it. You always take the battery in to any number of autoparts stores, and they can put it on a tester to see if it is good, and if so put a quick charge on it.
Eliminate any possibility of it being the battery before you move on!
Start with the most simple most direct diagnostics, eliminate the obvious before you start theorizing!
ChevySilverado
Jul 29, 2015 11:08 AM
2keybird
Dec 31, 2014 9:20 PM
sirhcsti
Jan 12, 2010 6:25 PM
ohiotom
Dec 17, 2007 9:28 AM
dude1987
Oct 21, 2007 11:05 AM
