1999 5.7 Tahoe -12 degrees timing
Old Sep 27, 2023 | 4:10 PM
Myhoeisbadass's Avatar
Default 1999 5.7 Tahoe -12 degrees timing
i have a 1999 5.7 tahoe and the PCM retards the timing -12 degrees as soon as you hit the gas. when we changed out the fuel injectors we had a few wires to pop out of the cavity on the harness plug. If a few of these are off ( in he wrong cavity) will it make the PCM change the timing to try and correct the fuel delivery. I know this is probably a weird question but im truly at a lost. BTW we ordered a new PCM and installed it and it still does the same thing as the old one.
Old Sep 30, 2023 | 3:41 AM
oilcanhenry's Avatar
ECM is likely the culprit.
Old Oct 16, 2023 | 3:51 PM
Brand new GM PCM and it still does it. Im wondering if something in the transmission is telling it to change
Myhoeisbadass
Mar 10, 2025 7:10 PM
Myhoeisbadass
Sep 13, 2023 2:17 PM
Myhoeisbadass
Aug 23, 2023 6:45 PM
dcoperator
Feb 21, 2015 7:24 PM
Marseyus
Sep 26, 2011 7:03 PM
