1999 K2500 suburban brake light problems
Old Dec 8, 2015 | 7:19 PM
cooltimg4's Avatar
Default 1999 K2500 suburban brake light problems
i have a 1999 K2500 suburban. The brake lights and flashers are not working but the turn signals are working. i already replaced the flasher/turn signal switch and tail light bulbs. that didn't help. Any ideas on what to do next?
Old Dec 8, 2015 | 7:22 PM
cooltimg4's Avatar
Also the fuse and relay in the fuse panel for the stop?flasher are empty spots Where is the fuse?
Old Dec 18, 2015 | 2:20 AM
justimagination's Avatar
Not sure about your situation, but I had similar problem on my 99 Tahoe. The right brake lamp went out and new bulb did not fix it. I took the lamp apart and found the socket where the bulb fits was corroded. I cleaned it and fixed the problem. Good luck.
David g.
