1999 No front a/c
Old Jun 28, 2020 | 6:27 PM
workonown's Avatar
Default 1999 No front a/c
New to the forum so i apologize but it think I am in the correct area. If this has already been covered a link would be appreciated. 1999 Suburban and the front a/c blows but not cold. Checked all the actuators and they appear to all be operable. I have checked the with gauges and it looks like the pressures are pretty close. I have noticed that the orifice under the hood is cold, is that correct? Any help would be appreciated.
Old Jun 29, 2020 | 8:34 AM
Cusser's Avatar
I had a bad actuator under the dash on our 2005 Yukon. After taking the cover off bottom, I disconnected the harness and turned the actuator to block off heated air, and ran it a year before buying a replacement Dorman actuator to fix it correctly.
Old Jun 29, 2020 | 2:40 PM
workonown's Avatar
Unfortunately they changed the air box consideribly between these years. I can see air mixture actuator moving on the outside but need to open up the air box to check actual movement.
ruggeri5054
Aug 2, 2016 8:06 PM
friesner_28
Jul 27, 2013 12:44 PM
440guy
Feb 10, 2012 8:36 AM
skippybriggs
Apr 29, 2011 11:43 AM
modracer
Mar 1, 2009 2:57 PM
