1999 OBS Tahoe Overheating Issue
Old Mar 11, 2021 | 7:39 AM
RGIII4505's Avatar
Default 1999 OBS Tahoe Overheating Issue
Hello all!! Brand new to the forum, thanks for having me!!
Kind of a long post here, I apologize in advance. I have a 1999 Chevrolet 2dr 4wd Tahoe with a 5.7L Vortec. A couple months ago I was having some heating issues and so I started out with replacing the heater core. While doing so, I discovered the coolant system was filthy with what appears to be old dex cool and possibly rust chunks all throughout the system. So, I replaced the heater core, water pump, thermostat, radiator and also the coolant temperature gauge/switch. While I had everything apart, I took a hose and flushed everything as well as I could, and at least got clear water moving throughout. After buttoning everything up, the heat works well, however, the truck is running around 238-240 degrees. Thinking maybe it was a bad sensor, I replaced it again.......same result. I purchased a laser thermometer and noticed that the temp was indeed staying around 238-240 at the head near where the coolant switch screws into the head. The passenger side was fine at around 195 degrees.
So, next I discovered that the upper radiator hose was getting warm, however it never builds up much pressure at all. You can even pop the radiator cap at 230 degrees and no pressure at all. And you can stick your finger in the coolant and its luke warm at best. I also noticed that the lower radiator hose is almost cold. Well, I assumed maybe I got a bad water pump, so I took the pump back and got another one and replaced it. Still, no cure.
A few things to note, no water in the oil or oil in the coolant. Does not seem to be losing any coolant. Truck runs pretty well, no skipping or rough idle, etc etc.
Any advice on what to go after next?
Possibly head gasket and/or intake leak?
Is it possible the head or block water jackets are plugged up on the driver side?
Any and all advice would be greatly appreciated. It'* beginning to get the pride a little haha. I'm almost to the point of doing what every man hates to do, admit defeat and take to a shop. Lol!!
Old Mar 11, 2021 | 9:17 AM
is the rad cap sealing the system? without pressure the coolant boiling point is reduced so it will overheat at lower temps. test or replace the cap.
Old Mar 11, 2021 | 9:29 AM
RGIII4505's Avatar
Yes, it has a brand new cap and brand new radiator.
Old Feb 19, 2025 | 11:26 PM
Dooshington's Avatar
Default What happened?
I have three same year, was my parents vehicle since it had 200 miles on it is got 220k now, they maintained it very well until my mom got a new vehicle and my stepfather put minimum effort at best at marinating it. So needed at the least a waterpump, throwing two o2 sensor codes, also having a molding problem inside that's so bad(pine day i accidentally closed the back diversify door on a cluster of big ol pine needles resulted in massive puddle in the back, doesnt explain the rest of the time).
I'm mainly interested in what other processes did you have to go through to get it right. Can go into detail with my **** show if anybody wants to come in lol
Alen Domelian
Dec 7, 2020 1:55 PM
VanKo
12
Oct 4, 2020 3:41 PM
Thommy
Nov 16, 2018 6:04 PM
Marcingee
Oct 24, 2014 4:11 AM
Cody27
Jul 14, 2014 1:50 PM
