1999 Suburban bad oil pressure sedning unit
New guy on the block. My 1999 Suburban (old body style) 3/4 ton with 454 V-8 and 4L80E transmission has developed a bad oil leak from the oil pressure sending unit.
I thought it shouldn't be a big deal to change it. Bought the new sending unit and a special socket to fit it.
Got back to the vehicle and got the socket on the sendor, and could not break it loose. So I added about a 4 inch cheater pipe to give me more pulling power. And the sending unit rounded off. Now the socket slips on it.
I don't see much of anyway to reach it get it out unless the upper and lower intake removal would give me access. Only other alternative I see is to pull the engine so I can get something onto what is left of the sending unit still in the block.
Anyone else run across this problem? Any other suggestions?
Thanks
Thanks
One tough situation. Soak the threaded area with PB Blaster. Also, I’ve seen sockets with a “cutting edge” that that are made to remove lug nuts, but if you try this, get prepared to remove the intake if this fails. I think you can probably get a pipe wrench on it with the intake removed, but someone correct me if I’m wrong.
SD
SD
