1999 Suburban bad oil pressure sedning unit
Old Dec 28, 2017 | 6:21 PM
rdrodgers's Avatar
Default 1999 Suburban bad oil pressure sedning unit
New guy on the block. My 1999 Suburban (old body style) 3/4 ton with 454 V-8 and 4L80E transmission has developed a bad oil leak from the oil pressure sending unit.
I thought it shouldn't be a big deal to change it. Bought the new sending unit and a special socket to fit it.
Got back to the vehicle and got the socket on the sendor, and could not break it loose. So I added about a 4 inch cheater pipe to give me more pulling power. And the sending unit rounded off. Now the socket slips on it.
I don't see much of anyway to reach it get it out unless the upper and lower intake removal would give me access. Only other alternative I see is to pull the engine so I can get something onto what is left of the sending unit still in the block.
Anyone else run across this problem? Any other suggestions?
Thanks
Old Dec 28, 2017 | 6:52 PM
kevinkpk's Avatar
Not seeing it, I can only suggest mixing epoxy, then filling up the area within the socket, and unit. Let it setup, that may keep the socket from slipping.
Old Dec 30, 2017 | 11:25 AM
Suburban Dude's Avatar
One tough situation. Soak the threaded area with PB Blaster. Also, I’ve seen sockets with a “cutting edge” that that are made to remove lug nuts, but if you try this, get prepared to remove the intake if this fails. I think you can probably get a pipe wrench on it with the intake removed, but someone correct me if I’m wrong.
SD
