1999 suburban shuts off
Old Sep 19, 2011 | 1:07 PM
BobJ's Avatar
Default 1999 suburban shuts off
I have just replaced the fuel pump on the suburban along with running a new power wire and plug to the pump its self. pump start and runs when you turn on the key. The truck will start some times and run for a short period then it just shuts off. If i give it gas and keep the RPM's up it will run for a couple of seconds longer but still shuts off it. it does not start all the time it seems to have to sit for a while. anyone have any ideas?
Old Sep 19, 2011 | 7:26 PM
hicksvilleshick's Avatar
check grounds. I had 2 bad grounds behind my inst cluster that was killing the motor.
but then it would depend on the kind of die your getting... is it a just a all out motor shuts off, is it sputtering then dying etc...
Old Sep 20, 2011 | 6:56 AM
BobJ's Avatar
No sputter just shuts off and wont restart till after it sits a while. I was looking into the fuel pressure regulator if it is failing closed it would just die is that correct?
Old Sep 25, 2011 | 8:55 AM
BobJ's Avatar
Fixed the issue found it to a bad crankshaft sensor. I used a actron scanner no codes were found. A friend of mine had a Snapon scanner found it was throwing P0336 & P0339 bad crankshaft sensor codes. This part was less then a year old took it out and got a replacement (Free) the truck is working fine now. learned a couple of things on this one I can tell you.
kornbred6
Feb 28, 2011 1:32 PM
ajrkar
Jul 21, 2010 11:26 AM
gators27
May 11, 2008 3:56 PM
bobbiejo
May 5, 2008 10:52 PM
TriVHo
Feb 18, 2008 4:14 PM
