1999 Suburban... What is this???
Yes, it does. I'll have to check that. So, do these things have two heater cores?
I've taken it around town and I can't get the needle off cold. Almost as if the thermostat has been removed, but I haven't checked to see yet. It supposedly had a blown head gasket at some point and it's hard figuring out what's going on here...
If the gauge is not registering anything other then cold, it may not be working or its disconnected...
It will most likely run rough and rich most of the time if there is no thermostat installed, particularly when its cold out... does the oil smell like gas? if so running rich will eventually take out the catalytic converter..
Ok, so I drove it to work this morning, maybe 10-12 minutes of city driving, heat never got anything above a degree or two above cabin temp. I got to work, checked the top radiator hose, it's not hot. The other odd this is it's also pressurized. That's a new one for me. Ideas?
