1999 Tahoe Odds and Ends
I have a 1999 tahoe that I'm selling for a friend, but it has a few problems I need to fix before I can sell it.
1 It has a coolant leak right below the serpentine belt in the direct center of the car. Is this the water pump going out?
2 The headlights are on all the time, whenever the car is running. You have to turn the **** to the on position to turn on the brights though.
3 I think a third row seat would be a huge added value to the car. Where do I find one to match and how much would it cost me.
Thanks, Gray
Thanks, Gray
Welcome to the forum.
Are there socket fittings in the floor for a third row seat? If not, will be real expensive to add. If there are, then a trip to the salvage yard should get you a good seat.
Thanks, Gray
Thanks, Gray
2: likely a bad auto headlight sensor... seems to be the case in my '01 anyhow...
3: I couldn't tell ya other than to look at junkyards...
:chug:
Thanks guys, I now I can add a third row now, but all I've been able to find is leather. I also got the headlight issue taken care of. Guess its time to find that leak.
