1999 Tahoe Rear A/C Blower
Old January 10th, 2023, 2:40 PM
  #11
Cusser's Avatar
I wouldn't go with a used part.
O'Reilly and Autozone should have Four Seasons or Murray 35015.
https://www.oreillyauto.com/detail/c...tor/mry0/35015
Autozone unit says lifetime warranty https://www.autozone.com/cooling-hea...015/911677_0_0
Either way, you'll need to swap the squirrel cage over to the new unit.
Old January 10th, 2023, 3:48 PM
  #12
Rednucleus's Avatar
And check out Rock auto. I need a new front blower for my 93 Suburban, several good choices there.
Old January 10th, 2023, 3:49 PM
  #13
repairman54's Avatar
Check Rock Auto out. They are all I use for parts than can wait for a couple days.
Old January 11th, 2023, 7:38 AM
  #14
04Z71SuburbanDude's Avatar
last time I used rock auto, I bought a coolant reservoir and it didn't fit. then I bought a tail light and it didn't fit. looked back at both of the product pages and they both said that they fit for a 2004 chevy suburban 1500. so I no longer use rock auto. go to auto zone or o'Reillys. but I mainly use eBay motors and have yet to have a problem.
Old January 11th, 2023, 8:15 AM
  #15
Cusser's Avatar
I use Rock sometimes. But tough to beat local lifetime warranties for certain parts !!!
Old January 12th, 2023, 7:25 AM
  #16
I certainly agree
Old January 12th, 2023, 7:48 AM
  #17
rosyod96's Avatar
Ok thanks for the suggestions…looks like my local autozone had them in stock. I went to pull the motor this morning and can’t seem to get it out. Haven’t messed with it a ton, but thought I’d see if there is a trick to it. It mounts from the top with 3 screws, (not on the side like the 2000+ models). Can’t seem to fit it out between the plastic duct it’s mounted in and the metal fender. Is there a way to remove the fan from the motor before you remove the motor?
Old January 12th, 2023, 10:54 AM
  #18
Cusser's Avatar
Fan assemblies typically mount to the motor shaft with an allen-head set screw.
Post some real good photos of yours from several angles; there's always a way, and replacement of a blower fan motor would not be an "unexpected repair" when engineering these.
Old January 12th, 2023, 1:18 PM
  #19
rosyod96's Avatar
Hey I did manage to get it. Fairly simple, just popped the two bolts holding the top of the entire ductwork to the vehicle, and was able to pry it out enough to slide the fan assembly out!
Rednucleus (January 12th, 2023)
Old January 19th, 2023, 11:23 AM
  #20
rosyod96's Avatar
So got a new motor installed and it’s blowing the fuse again…next suggestion? Read somewhere mabe it could be the resistor?
Quick Reply: 1999 Tahoe Rear A/C Blower
