2000 chevy suburban start problems
my suburban will turn on but once we turn it off and try to turn it back on it sounds like its out of gas. i've already changed the fuel filter, fuel pump, the regulator,air filter and the charcoal canister, turns on and drive's but if we turn it off it won't start for at least 20 to 30 minutes. autozone gave me the code -0449 but thats all i have to go on . just about to go crazy cause it's cost me a pretty penny , if any1 can help i would appreciate it
thanks in advance
john
thanks in advance
john
jokester4769 Welcome to the forum,
Might try checking the fuel pressure just to rule out any blockage or any other fuel delivery issues... are you using E85? have the injectors been serviced? check the IAC ( idle air control) sticking EGR?
Kinda almost sounds like vapor lock...
well guys i just changed the crank shaft sensor and it's runnuing fine , i'll have to wait til 2maro to see if its what it needs. i'm hoping 2maro morning it fires up cause i'm almost to the point of pouring 2 bucks of gas and lighting her up. thanks again for all the input . and no i'm not using e85
looks like the crank shaft sensor wasn't it. doing the same thing. started this morning and 15 minutes later would'nt start. gave it about an hour then it started again.
Refer to post #2. The PCM (power train control module) regulates the rate of vapor flow to the intake by controlling the vent valve solenoid duty cycle. During cold start or hot start time delay it leaves the solenoid shut. After the engine is warmed up it purges the vapors into the manifold for combustion. That brief explaination AND code 0449 tells me the purge vent valve is not working as it should. I don't see the vent valve solenoid, but the valve is about 40 bucks at autozone. I'd say the solenoid is the issue not purging, or staying open (inoperative) as your issue.
