2000 rear axle swap
Old Jul 17, 2011 | 11:49 AM
littlebears911's Avatar
Default 2000 rear axle swap
I replaced my stock 4.10 rear axle, which blew, with a 3.73 limted slip, it's running well, but I've noticed my transmission is not upshifting as it should. It shifts through the gears fine an does not slip, but I have to back off the throttle a splitt second when accelerating. This only started when I swapped rear axles, is this a result of the different ratios an a computer issue?
Old Jul 19, 2011 | 9:48 PM
Welcome to the forum.
Is the transmission electronically controlled? Not sure what you meant by backing off the throttle when accelerating. Are you saying that the tranny doesn't shift unless you do that?
chevy83
Feb 10, 2014 8:13 PM
chevyspudz
Feb 28, 2013 6:40 PM
gmlover
Feb 16, 2010 10:31 AM
lknox21
Sep 5, 2009 7:29 AM
mudmaniac
K5 Blazer
Nov 25, 2008 6:38 PM
