2000 tahoe hard start
Old Nov 1, 2011 | 5:13 PM
bull463's Avatar
Default 2000 tahoe hard start
Hi All
Just found the site. My 2000 tahoe starts hard after warm up. I have a new fuel pump and have ran sea foam through it I have to give it some gas then starts but turns over alot. The truck starts right up if cold. I have put new plugs and fuel filter in. The tahoe has a 5.3 eng and about 100000 miles runs fine when it starts.
Thanks
Bull463
Old Nov 1, 2011 | 10:23 PM
EinST's Avatar
Welcome to the forum. Which came first, the problem or fuel pump, sea foam, new plugs, or fuel filter? Was the fuel pressure checked at some point?
Old Nov 2, 2011 | 7:28 AM
bull463's Avatar
the fuel pump was replaced first
Old Nov 2, 2011 | 11:31 AM
EinST's Avatar
Well, can you be more specific? You replaced the fuel pump and started having the warm start problem? The sea foam, new plugs, and fuel filter were to try to counter the said problem? Why did you replace the fuel pump in the first place? You never checked the fuel pressure before or after? How long after you replaced the fuel pump did you start having the warm start problem?
Old Nov 3, 2011 | 8:35 AM
2000TahoeLT's Avatar
I had the same problem on the same car when I first got mine. I tried everything you tried with replacing plugs, wires and fuel filter. I spent too much money at a mechanic to get that only to find out on my own the fuel pressure regulator needed to be replaced. It was only like 48 bucks from O'Reillys and took like 5 minutes to install. Now my car starts on the first try every time. Hopefully this helps.
Old Nov 3, 2011 | 9:23 AM
bull463's Avatar
Hi Guys
I think I may have found the proublum I have gas coming out of the vacume of the fuel pressure regulator in reading some things on here that is not good I have ordered a new one to put on and well see. Oh the fuel pump stopped working so that was the first thing I had to do.
Old Nov 11, 2011 | 6:52 AM
bull463's Avatar
Update just put in a new fuel pressure regulator fixed the proublum runs great. Thanks for all the input on this
bigchevbob
Oct 17, 2012 10:30 AM
izod
Feb 14, 2009 2:42 PM
kyle_thede
Nov 7, 2008 1:58 PM
silverado man
May 5, 2008 11:53 AM
pyrofytr
Jul 10, 2006 8:38 PM
