2000 Tahoe p0300 pd
Old Aug 19, 2010 | 1:45 AM
83redneck's Avatar
Question 2000 Tahoe p0300 pd
2000 tahoe 5.3l gives p0300 and p0300 pd trouble codes I replaced fuel filter, the EGR valve, and the EVAP purge solenoid to no evail it still idles rough. What could it be pcv seems to be clear I tested fuel pressure it stays between 46-48 psi. I look forward to any ideas already spent two hundred in parts can't spend much more help
Old Aug 19, 2010 | 4:33 PM
nsthegodfather5's Avatar
have you tried a tune up i had the same problem with my firebird, then got a tune up and ran fine after that.
Old Aug 19, 2010 | 9:20 PM
give this a try....
http://ww2.justanswer.com/uploads/Bl...e_cleaning.pdf
Old Aug 19, 2010 | 11:23 PM
83redneck's Avatar
Thanks nsthegodfather5 tune up fixed it, someone had also put platnium plugs instead of iridium which is the oe plug but runs like normal now. FYI fuel pressure is 42-50psi
georgiatahoegirl1980
Dec 27, 2021 7:06 AM
Patkz
Jan 17, 2015 1:22 AM
jgharding
Dec 15, 2014 4:53 AM
moaabyss
Apr 30, 2013 8:47 PM
sdavis_0204
Oct 6, 2012 12:50 PM
