2000 Tahoe Various Warnings Flashing on and off.
Old Apr 23, 2017 | 6:16 AM
Horseman's Avatar
Default 2000 Tahoe Various Warnings Flashing on and off.
It started with SECURITY and that appears to be caused because driver side rear door lock is stuck half way and can't move it manually. Then fuel gauge would drop to zero and low fuel would flash. Then battery light would flash but gauge would show 14. Temperature gauge would drop to Zero. When you start the engine at first everything is normal.
Old Apr 23, 2017 | 5:46 PM
intheburbs's Avatar
Check for loose ground wires and battery cables.
Old Apr 24, 2017 | 6:11 AM
Horseman's Avatar
Thanks
Battery is very secure. Even disconnected ground for 1 hour hoping everything would reset. No luck.
