2001 Chevy Tahoe LT heater issues
Old Dec 3, 2022 | 9:47 AM
missing's Avatar
Default 2001 Chevy Tahoe LT heater issues
Is there a troubleshooting methodology for a 2001 Tahoe heater issues. Heat works on upper setting. if you change to defrost/heater it blows cold air. if you change to lower setting, it changes to outside air only and will not change back to recirculating. I would prefer to go through a troubleshooting routine rather than R&R parts till it works correctly. Any suggestions would be appreciated. thanks in advance
Old Dec 3, 2022 | 10:11 AM
Welcome to the forum.
Old Dec 3, 2022 | 10:34 AM
Rednucleus's Avatar
Welcome to Chevy Missing! Lot of smart folks here will help you with your problem, stay tuned. These heater/ac posts are a common complaint.
I got nothing for you - I'm a veterinarian, not a mechanic!
missing's Avatar
Thank you, appreciate the group.
Old Dec 4, 2022 | 9:07 AM
Cusser's Avatar
Disclaimer: My hands-on experience comes from a 1994 and a 2005. There are electrically-actuated flaps/"doors" in the vent system under the dash; my 2005 had three of these. These direct the air flow to outside/recirculate, to windshield (defrost) or heat underneath the dash or to vent right at the driver and passenger. The third one may be for driver/passenger split. Oftentimes when these go bad one will hear a clicking from stripped gears.
For our 1994 I paid the shop $400 to replace one (which fixed it), for the 2005 I replaced one actuator with an aftermarket Dorman part. In the 2005 I could hear/feel which actuator was bad after removing the bottom panel with a 5.5mm shortened socket, and I unplugged the harness and turned the actuator with a screwdriver, and drove it like that for months. Then I replaced it, was easier than getting the bottom panel off !!!
One thing to try: disconnect a battery cable for 30 minutes to re-set the computer, then try.
Old Dec 5, 2022 | 8:12 AM
repairman54's Avatar
Recirc is not allowed on certain settings. It's so humid, moist air is driven out of the cabin to help clear windows.
kmcman
Dec 12, 2014 9:31 AM
Fletcher34
Mar 15, 2013 9:20 AM
Larry.glaude
Nov 15, 2012 1:41 PM
nachitoxxx
Apr 3, 2010 6:58 PM
Mickbear76
Jan 5, 2010 5:01 PM
