2001 Chevy Tahoe Volt meter bouncing
Old Aug 4, 2024 | 3:16 PM
jth_tahoe's Avatar
Default 2001 Chevy Tahoe Volt meter bouncing
Hello, I drive a 2001 chevy Tahoe and I had an issue where the volt meter was bouncing and the headlights would flicker while driving. I took it to a mechanic and they said the alternator was going bad, so I had them replace it. They said battery was good and everything looked normal. Now a week later, the problem is back and I am trying to figure out where else the issue could be coming from. Looks like all the cables have good connection. Could this be caused by a bad tensioner on the serpentine belt? Any help would be appreciated. Thanks.
Old Aug 5, 2024 | 8:08 AM
Welcome from Florida. I would have the battery tested. Check your battery cables at both ends.
Old Aug 5, 2024 | 9:41 PM
jth_tahoe's Avatar
Thanks, checked the battery and it is good. I am wondering if a bad ground connection could cause this and if so, how to find it and correct it?
Old Aug 6, 2024 | 8:42 AM
Cusser's Avatar
Not a bad idea to disconnect the ground/negative cable and ensure that all the connections are clean and shiny, like to use steel wool. Ground spots can include body, chassis, and engine.
I did all that on my 1988 Mazda truck last year.....
Old Aug 24, 2024 | 2:34 AM
jth_tahoe's Avatar
Thanks for the replies. It turned out to be a bad alternator after all. I replaced it and now my volt meter is steady and headlight flicker is gone.
Old Aug 24, 2024 | 8:58 AM
Cusser's Avatar
Great !!! Mechanic was apparently correct but just got a crappy new part first time !!!
Sawyer.Linkowski
Nov 6, 2014 2:42 PM
tahoe2001
Mar 2, 2012 9:13 PM
rjenvision
Mar 2, 2012 6:05 PM
KeithKman
Dec 5, 2009 9:14 PM
aknight_sa
Oct 12, 2007 12:08 AM
