2001 rear passenger door
Old Feb 28, 2011 | 10:15 PM
tallred37's Avatar
Default 2001 rear passenger door
I need help please. My 2001 Suburban rear passenger door will not open/unlock manually or power and therefore all my passengers have one door that opens and has to climb over the middle seat to get to the 3rd row seating.
Old Mar 1, 2011 | 7:05 AM
RacerX's Avatar
you will have to take off the door skin from the inside and pull on the rod. Probably a seized power door solenoid
Old Mar 1, 2011 | 3:54 PM
Welcome to the forum. Doesn't the middle seat flip down for access to the third row?
Old Mar 1, 2011 | 7:00 PM
Does it open from the outside handle? if so check the child safety lock on the door near the latch assembly make sure it has not be engaged....
Old Mar 2, 2011 | 10:22 PM
tallred37's Avatar
The seat that flips down is by the door that won't open. It will not unlock from outside or inside.
Old Mar 3, 2011 | 9:37 PM
May need to do your best to get the door panel removed and manually actuate the door so you can find out what is going on....
Attached Thumbnails 2001 rear passenger door-4d70099d.jpg   2001 rear passenger door-2001-rear-door-trim.jpg
dubbs900
Oct 12, 2014 2:42 PM
TBFire
Jun 29, 2009 6:54 PM
cmcburke
Jan 28, 2007 6:56 PM
davemec
Sep 25, 2006 11:52 AM
