2001 Suburban 2500 LT Oil Leak
Old Jun 20, 2010 | 7:15 PM
kbourne's Avatar
Default 2001 Suburban 2500 LT Oil Leak
On my 2001 Suburban 2500 LT 2WD 6.0L it is leaking on both front corners of the transmission pan. The oil drips (on the passenger side) down the retaining bolts for the starter motor and along the bell housing cover. I have replaced the valve cover gaskets, the oil pan gasket and the oil cooler gasket. It is not red and it smells slightly burnt so I would say it is oil. Also a month ago I had the flywheel replaced and why they were in there they put in new tranny fluid and tranny pan gasket.
Anyone have any ideas?
Thanks
Old Aug 28, 2010 | 8:56 AM
stldrgnrdr's Avatar
I have the exact same problem. It is driving me crazy. I have only replaced oil cooler gasket. Some think It might be rear main seal, but on yours they should have noticed that while replacing the flywheel. I was going to start with oil pan gasket and go from there. Any hints on its removal?
Old Aug 30, 2010 | 4:37 PM
kbourne's Avatar
Default oil pan gasket
Sorry no hints.. Looks like it is not to difficult.
Local mechanic said it may be the rear main seal. Taking it to a dealer tomorrow to look at the oil leak and the air conditioning tensioner pulley making noise.
Will let you know..
Old Aug 31, 2010 | 4:52 PM
kbourne's Avatar
Took it to the dealer today and they said it could be a transmission seal. Recommended I take it back to the tranny shop that did my previous work.
plex4r
Sep 18, 2022 8:34 AM
kirkgrau
May 6, 2022 9:38 PM
KeithKman
Jan 13, 2019 5:44 PM
dkrukosky
Apr 2, 2013 10:52 PM
grndslm
Dec 18, 2012 2:38 AM
