2001 Suburban differential
2001 Suburban 1500. One day the rear differential started a loud clanking, forward or reverse, and would not move. Opened up the cover. What I see is a bearing on the right side of the yoke exposed. It's cover ring is loose. I can see the bearing rollers. Ideas as to repair approach?
Hello everyone,
Yes indeed it is serious. As you may know I can remove the differential yoke and go from there in an evaluation and rebuild, but that requires pulling the axles. I am very curious if anyone has seen/heard of the right diff bearing coming apart and what caused it. For me, it's a little confusing to understand why there can be extra space inside the differential. The gears inside have taken a little abuse, but not bad since I shut the engine down right away.
