2001 Suburban differential
Old Mar 26, 2018 | 3:00 PM
rafur001's Avatar
Default 2001 Suburban differential
2001 Suburban 1500. One day the rear differential started a loud clanking, forward or reverse, and would not move. Opened up the cover. What I see is a bearing on the right side of the yoke exposed. It's cover ring is loose. I can see the bearing rollers. Ideas as to repair approach?
Old Mar 27, 2018 | 8:47 AM
Suburban Dude's Avatar
Can you get it to a drivetrain specialist shop? I’m thinking you’ll need to pull the gear set and get the bearings replaced, probably on both sides.
Old Mar 27, 2018 | 9:42 AM
falconbrother's Avatar
That sounds serious. I think it's going to need to be replaced or, if the housing isn't damaged, rebuilt. These 9th gen rear ends don't impress me all that much.
Old Mar 27, 2018 | 7:07 PM
rafur001's Avatar
Hello everyone,
Yes indeed it is serious. As you may know I can remove the differential yoke and go from there in an evaluation and rebuild, but that requires pulling the axles. I am very curious if anyone has seen/heard of the right diff bearing coming apart and what caused it. For me, it's a little confusing to understand why there can be extra space inside the differential. The gears inside have taken a little abuse, but not bad since I shut the engine down right away.
