2001 Suburban Heater Blend Door - hot is cold, cold is hot
I inherited my father in laws 2001 Suburban. Recently the Blend Door Actuator broke and I replace it. Seemed a simple fix, which it was. I followed all of the steps to re calibrate it, and I cannot figure out why I problem with the heat/cold selector switch.
When the dial is turned to heat, it blows cold, and when turned to cold, it blows hot. I have taken it off several time and it turns OK, and works when you turn the heat control dial, but it is backwards.
For the life of me, I have searched this everywhere and I cannot find a solution to this problem. Any advice would be greatly appreciated.
Thanks
Thanks
egeiro
April 8th, 2017 5:03 PM
Stephen Doak
February 2nd, 2013 6:48 PM
