2001 tahoe 5.3 fuel problem
I found the fuel regulator leaking and extended crank on start up, put a new gm regulator on and there is a grinding/restriction type noise from pump, fuel rail, and fuel filter. I put the old regulator on and its gone, so i thought the regulator must be bad, installed another new one and the same thing.
So i thought the pump must be going bad, i put a new gm fuel pump in and a new gm fuel filter in. Same thing.
If i unplug the vacuum line from regulator the noise is gone, noise is only at idle. Truck drives perfect even at idle when its making the noise.
Any ideas?
Any ideas?
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
