2001 Tahoe with Rear AC only; front AC blows ice cold, rear is hot
Old Jun 26, 2011 | 12:03 PM
  #11
srwilliams's Avatar
My 2001 Tahoe is having the exact same problem. The compressor was making a lot of noise and I had it replaced by the local dealership. Now the AC intermittently does not work. Did you ever find a solution to the problem? Any help would be greatly appreciated.
Thanks,
Sam
Old Jun 26, 2011 | 2:25 PM
  #12
Welcome to the forum.
Did you have the intermittent problem before the compressor replacement?
Old Jun 27, 2011 | 10:22 PM
  #13
srwilliams's Avatar
No the AC cooled fine before the compressor was replaced.
Old Jun 28, 2011 | 12:07 AM
  #14
Then I'd take it back to the dealership and tell them to fix it.
Old Jun 28, 2011 | 4:10 PM
  #15
Your repairs at the dealership should be covered by a 12/12 warranty from the date of that repair(for that repair), if you are within that period you should not have to pay anything out of pocket...
Old Jun 29, 2011 | 5:48 AM
  #16
srwilliams's Avatar
Thanks that's a big relief. I brought it back to the dealer once already, but the problem is intermittent and the AC worked when they were checking it out.
Old Jul 3, 2017 | 8:50 PM
  #17
ronand2020's Avatar
Thanks,
Sam
I would check the Idler pully for the compressor and make sure it not loose or worn. My was jumping because it was loose cause intermittent coolong.
Old Jul 13, 2018 | 6:44 PM
  #18
Jairo Escobedo's Avatar
so did u ever found out what the problem was?? im having the same issue on my 01 tahoe
Old Aug 28, 2020 | 3:36 PM
  #19
Mike Raposo's Avatar
I'm wondering if the failing compressor let go of some pieces and they carried thru the system and clogged the rear system.
Check the rear blend door actuator
Bryris
Jan 22, 2015 6:07 PM
Buckmaster73
Jun 28, 2012 9:09 PM
jennkent5454
Jan 12, 2010 5:41 AM
relewis47
Jun 23, 2009 9:34 PM
btuck
Dec 7, 2006 1:40 PM
