2002 Suburban brake issues
Old Oct 28, 2015 | 6:58 PM
captgreenowl's Avatar
Default 2002 Suburban brake issues
Had a brake leak but was able to easily change the line thanks to the help from this forum. I was told I also needed to bleed the system. That's where I ran into the first problem. When I started with the right-rear, the bleeder valve was literally stuck on. I tried penetrating oil and used a 10mm wrench. It look like it has become a 9mm screw maybe because the sides were worn.
How do I replace the a bleeder screw that is stuck with worn sides? I already got the new bleeder screws but I'm going through hell removing the current ones and I just started. Any videos or write-ups to guide me?
Thanks in advance.
Old Oct 28, 2015 | 9:34 PM
the only 100% sure way of removing frozen bleeders screws is to heat the screw to cherry with a torch and then quench it with water. repeat 6x. Once it out, install a new screw.
keep the heat off the flex hose...wrap the hose with a wet rag.
if the screw breaks and you cannot extract it....you will need new calipers.
before you do anything....what leaked? Did the master go dry?
Old Oct 28, 2015 | 10:13 PM
The rear axle line was rusted and leaked when I was pulling out of my driveway. Was able to change that with copper-nickle lining from ebay. I made sure the brake fluid level never dropped below min.
What do I use to grab the bleeder screw after heating/cooling, since the sides are kinda worn?
Old Oct 29, 2015 | 7:29 PM
vise grip pliers
you should only have to bleed the back in the reservoir did not empty.
next time you replace lines; slightly apply and hold the brake pedal with a long pry bar against the seat. this closes off the ports in the master so it won't empty and stops the constant draining of fluid.
