2002 Suburban fog light switch wiring
I just purchased some PIAA 60xt's to replace the fog lights on our 2002 Suburban. After some careful dremel shaving of the valance and redesigning of the factor fog light brackets they fit perfectly. PIAA supplies a switch, but I want to keep the factor look of the dash. I want to utilize the factory fog light button. I pulled out the factory fog light button & rear widnow wiper assembly and found it is all one piece with one wiring pigtail/harness going to it.
So I took the PIAA switch and cut the wires off of itand I was going to wire it into the factory pigtail but I can not find a wiring diagram for the factory pigtail. I am now left with the PIAA wiring which is 3 wires (Red, White, and Black) and no idea what wires to replace them with in the factory pigtail/harness. The factory plug that goes into the back of the assembly looks easy to disassemble but once done where do I put the PIAA Red, White, and Black Wires?
Any help would be greatly appreciated. thanks....
The foglight button and the rear window wiper switch are all one unit with multiple wire running into. Which wires, out of the 7 or 8 wires, do I utilize? Thanks again for your help.
the purple wire in the back of the switch is the powered wire when the button is pushed. Black is black aka ground.
ericnottelin
Jul 7, 2010 9:30 AM
juddkennedy
May 17, 2010 9:24 AM
