2002 Tahoe issues
Old Jul 29, 2021 | 2:34 AM
carterk's Avatar
Default 2002 Tahoe issues
At one point my 2002 Tahoe had a wet floor board. I cleaned it out and checked if anything was rusted out, which it wasn’t. Didn’t see an issue for awhile, then I have recently been dealing with a lot of heat coming up from the driver side that sometimes gets really hot. Also my car died in reverse and I have no clue what could have caused it. Please help.
Old Jul 29, 2021 | 5:21 PM
2001 chevy silverado's Avatar
Do the dollar test on all your doors and windows. If you can shut the door/window and still slide the dollar: it is enough to get your floor wet. All the seals including the bottom ones and the fuzzy ones the window slides on.
The hole on your hood lets air in for the cabin air fan. They usually are designed so they can never leak - but not on all cars.
What I'd do at the dealer? Get a hose start spraying. See where the water gets in.
Old Jul 29, 2021 | 5:22 PM
well, that's not related to a water leak
If when you cleaned the white rag looked yellow, we'd all assume you knew it wasn't water wetness, and that your heater hose has a leak.
Old Jul 29, 2021 | 5:24 PM
heater hoses coming loose can leak. usually that will be in the engine compartment on the firewall and have no chance venting heat and water in the cabin. perhaps on your model it's inside the cabin, leaked a little, and you had 0 water in the hose after and hot engine air came in the cabin. or perhaps the heat was from the heater core heating up - or perhaps you have floor vents and those were blowing heat though you didn't realize the floor vents were active
how's your radiator fluid level? it's 50% 50% specific gravity and not loosing fluid right?
and your trans went out in reverse? ugh. you need to post different questions in differnt posts.
AndyL3
Apr 11, 2021 12:34 AM
SB1979
Nov 28, 2019 9:46 PM
troybuddy
Sep 9, 2018 3:01 PM
oldcarguy65
Jul 28, 2017 4:21 PM
thehop
Apr 4, 2017 7:06 PM
