2003 chevy tahoe a/c issues
Old Jun 28, 2012 | 12:20 PM
Buckmaster73's Avatar
Default 2003 chevy tahoe a/c issues
All I need help here. My 2003 Tahoe lost all pressure. I pulled vacuum and recharged the system. My rear was blowing cold, front blowing hot. I pulled the actuator from the front ac located in the center and swapped it with the back no change. The next day i lost all pressure again. Vacuumed system again filled with dye a Freon. I found the 2 back lines had die on them. Once I replace these should that fix the problem with the front ac? our do I have another issues as well? I would like to fix it all at once while I got it apart. Please all your help is much appreciated.
Old Jun 28, 2012 | 2:41 PM
kevinkpk's Avatar
Maybe, maybe not. Troubleshooting 101, fix the known, as your case with leaks, then go to the next step.
ohioguy
May 2, 2022 9:10 AM
Wranglin4Life
Sep 12, 2014 5:47 PM
chevygirl89nm
Feb 14, 2013 10:00 PM
Ldreamaz
May 25, 2011 7:37 PM
Mercedestech
Avalanche
Jan 7, 2010 10:10 AM
