2003 Suburban 1500 dual climate control problem
Old Oct 30, 2019 | 11:30 AM
Raphell's Avatar
Unhappy 2003 Suburban 1500 dual climate control problem
My problem appears to be different from most on here. On auto the passenger side thermostat works correctly but the driver side wont turn up past 69 degrees. if I keep turning it up it gets to 69 then starts to turn down. If i do it on degree then wait a few minutes and turn it up 1 more degree then repeat process sometimes I can get it to as high as 71 before it jumps back to 65. Any ideas what I need to do to fix it. This is my wife's everyday driver and she is tired of being cold.
Old Oct 30, 2019 | 6:05 PM
oilcanhenry's Avatar
Might be your ambient atmo temp. sensor needs to be re-calibrated. Turn the key on and hold the A/C and Recirc buttons at the same time for 5 seconds. That will solve that issue.
Old Nov 4, 2019 | 10:34 AM
Raphell's Avatar
That worked. Thank you so much oilcanhenry.
KBw04.2500
Feb 26, 2019 11:17 AM
TxBowHunter
Dec 29, 2014 9:38 AM
warden48
Jan 11, 2011 3:35 PM
GRASSHOPPERNC
Oct 12, 2010 10:41 AM
punkieys17
Mar 10, 2008 8:05 AM
