2003 Suburban AC not cold in front but cold in back
Old Oct 10, 2020 | 5:06 AM
Kajdkmm7's Avatar
Default 2003 Suburban AC not cold in front but cold in back
My front AC is not cold but my rear AC is cold. Freon checked good. Compressor seems to cycle often not sure if that is normal?
Old Oct 10, 2020 | 5:41 AM
oilcanhenry's Avatar
Can you get hold of an A/C gauge set? That might help Immensely in solving your issue. The compressor was intended to cycle, BTW.
Old Oct 10, 2020 | 10:27 AM
Cusser's Avatar
Post both low side and high side pressures at about 1800 rpm with compressor running.
NEVER ADD ANY SEALERS OR REFRIGERANT CONTAINING SEALERS !!!
Old Oct 10, 2020 | 11:13 AM
PNW NBS Z71's Avatar
May have a blend door actuator problem or a controller panel problem, but yes, post the basics first. The pressure gauges help to see what is going on inside the system. But the actuators are a known weak spot. Check out a you tube video or 4 to see what I am talking about.
Sample of the controller, since I have no idea which you have: https://www.rockauto.com/en/moreinfo...12198&jsn=1693
Sample of the actuator: https://www.rockauto.com/en/moreinfo...12198&jsn=1763
Craigh
Sep 6, 2023 2:36 AM
stevend
Jun 2, 2018 4:30 PM
StreetDreamsCC
Aug 17, 2013 8:16 PM
Jersybehr
Jul 30, 2013 1:12 PM
alanbmx
Feb 13, 2011 7:08 PM
