2003 Suburban Flex fuel bypass
Old Aug 22, 2019 | 9:19 PM
Larry McBain's Avatar
Default 2003 Suburban Flex fuel bypass
On my 2003 Suburban the Fuel lines are leaking due to rust. Also the Flex Fuel Sensor is cracked not leaking at this time. I would never put E-85 in anything I own. I do not have any Codes at this time and the car runs fine. I am looking at replacing the fuel line with the non-flex fuel lines. I have to replace the lines anyway and this would bypass the Flex Fuel Sensor. If I get a code in the future, I would plug in one of the electronic bypass switches from the internet. Do any of you see a problem with this plan.
Old Aug 22, 2019 | 10:11 PM
you can do it that way.
I would replace it with plastic fuel lines. Its the cheapest and easiest method should be ff compatible. you use unions to join from metal to plastic or plastic to plastic.
