2003 Suburban Transfer Case Clunk
Old Sep 10, 2015 | 1:40 PM
lexisdad1201's Avatar
Default 2003 Suburban Transfer Case Clunk
I am looking to buy an 03 Suburban. When testing it out, it clunked when we switched it from 4 high into 4 low and when we took it from 4 low back to 4 high or 2wd. It seemed to drive fine in all modes, but the clunking noise when it changed within the transfer case has me worried. Does anyone know what could cause this? Should I stay away?
Old Sep 10, 2015 | 4:46 PM
Scotiapilot's Avatar
one mans clunk is another mans clink. mine always clunked to some degree. if you were on the brakes when shifting it tends to clunk more as there is little give. Mine wouldn't clunk so hard if I shifted between the two while my foot was off the brakes.
Old Sep 11, 2015 | 11:43 AM
SWHouston's Avatar
The clunk is pretty much normal Chevy.
Most times it's just when you change from 4lo to 4hi.
You can suppress it some, if you shift into neutral about 5mph, then press the shift button, and when you hear it change, put it in Drive and you're on your way.
slepley
Dec 29, 2011 4:21 PM
Deice5
Apr 17, 2011 9:27 AM
Curt
Jun 2, 2010 3:27 AM
chevythunder25
Mar 18, 2009 6:33 PM
lucleb
Jan 14, 2009 10:56 PM
