2003 Yukon 5.3L coding issues
Old Nov 7, 2020 | 7:01 AM
zmann96's Avatar
Default 2003 Yukon 5.3L coding issues
I've had a coding issue for a few years. went away once a while back had done none and now it's back.
Codes P074 and 071 both banks lean. The truck runs good, gas mileage ( not from on board) going 75-80 mph 15.7mpg.
I plugged in my scanner and this is what I have.
MIL status Off ? temp was up to 195
TPS 5.9% no movement
RPMs 530-560
MAF .83
MAP 11.2
Timing 17.5
Bank 1 LT trim 9.4
Bank 1 ST trim 0 - +1.6
Bank 2 LT trim 25 pegged no movement
Bank 2 ST Trim 23 - 27
I've done all the leak tests smoke - air pressure - propane didn't find any.
Can you tell me what the values should be for this 5.3L NA at idle?
Ianmac
1988 - 1998 (GMT400)
21
Mar 22, 2020 11:34 AM
cameron.bunch
Mar 17, 2020 4:15 PM
terrydo
2014 - 2018 (GMT-K2)
Oct 17, 2019 3:47 AM
bretware
Sep 13, 2010 7:22 PM
