2004 Avalanche ..Service 4 wheel light error.
Old Mar 27, 2019 | 12:43 PM
Papachris's Avatar
Default 2004 Avalanche ..Service 4 wheel light error.
Have changed Computer, switch and Transfer motor...error leaves and then comes back when I hit a bump ...any thoughts?
Old Mar 28, 2019 | 12:30 AM
get it scanned.
Old Mar 28, 2019 | 5:52 AM
Papachris's Avatar
Thnx for the reply...I have already had it scanned on 2 different machines.......Even though the Service 4WD error is displayed , it shows no codes.
Old Mar 28, 2019 | 12:36 PM
Was it scanned with a GM Tech2 or MDI scanner? Only a dealer or mechanic with access to GM tools can read drivetrain codes.
Old Mar 28, 2019 | 1:55 PM
Papachris's Avatar
Actually, I am unsure. All I know is the guy told me it was pretty expensive......lol
He runs a pretty good sized independent shop, so I am not sure...
Old Mar 28, 2019 | 2:16 PM
It's also possible that driving over bumps is jostling a loose connection somewhere, and it's triggering a loss of communication. I would re-seat the connector on the transfer case control unit, and inspect the related wires for damage or loose grounding connections.
Old Mar 28, 2019 | 6:01 PM
Papachris's Avatar
Awesome................I was thinking a loose connection, Because when the light is NOT on, everything shifts smooth as silk....
Will check the wiring.....Thnx for the help...Chris Taylor
