2004 suburban unknown driver
Old Feb 13, 2014 | 7:12 AM
frydaddy's Avatar
Default 2004 suburban unknown driver
Dash says unknown driver,door locks, window's, radio,and dome like dosent work.i have 2 keys and 2 remotes neither will work. Truck turns over and runs for 2sec then shuts off. Battery is fully charger and never was dead.
Old Feb 13, 2014 | 6:25 PM
frydaddy's Avatar
Ended up being some corosion on the ecm terminals
Old Feb 19, 2014 | 10:06 PM
JDP1978's Avatar
I am having this same problem on my 04 silverado. I am able to drive mine though. I disconnected my battery for about a half hour and reset the key fob. This worked, but the next day it happened again. I just tried it once more and will see if it works right tomorrow. Where were the ecm terminals? Sounds like I may want to check these on my truck. Thanks!
Old Feb 20, 2014 | 6:42 AM
frydaddy's Avatar
On my truck it is to the left of the battery and down under a black cover
Old Aug 7, 2015 | 12:01 PM
Cardship's Avatar
Fixed it! Found the issue on mine. The dash lights would cut out randomly and leave nothing but the gauges working. Then it would give me unknown driver and not start, no radio and no dash. Some days we would go to start it and the battery would be dead. Ongoing issue, intermittent. Today it stayed on unknown driver long enough for me to troubleshoot so I: 1. Put key in the ignition and turned it to On 2. Removed the fuse cover under the back seat. 3. Pulled module fuses until suddenly the door ajar started sounding and the radio came on. 4. Looked up the fuse location. For me it turned out to be the PDM, which stands for the passenger door module. I have had issues with the passenger door electronics before so this didn't come as a great surprise. It seems any module that is connected to the BCM; DDM, PDM, Radio, Ect.. can cause this kind of issue so just remove power from each of the modules until you find the culprit. Best of luck.
Shelton53
Jan 21, 2023 8:20 AM
blazermoneypit
Aug 7, 2015 12:02 PM
acrummey
Jun 22, 2011 10:26 AM
Biff
Apr 5, 2011 7:57 PM
onecupguy
Mar 21, 2006 10:58 PM
