2004 Suburban waterpump fan removal ?
Old Dec 25, 2009 | 8:05 PM
hayseed's Avatar
Default 2004 Suburban waterpump fan removal ?
merry xmas -- my waterpump went out yesterday 12/24 whohooo.. anyway i am trying to figureout a way to remove the fan nut and do i have to remove the fan shroud ? any help would be appreciated
Old Dec 26, 2009 | 3:22 AM
tm4hammer's Avatar
Default bad timing
hard luck huh 1 your application requires you to remove the fan it is threaded to the water pump by a large nut you will probobly need a large adjustable wrench ,leave the belts on it will help hold the shaft from turning , the fan should slide forward enough to clear enough workspace and the shroud can stay in place pull the water pump pulley, drain the coolant,pull belts, remove hoses, remove the four bolts and brackets and reverse the order remember to hand tighten fan then install belts then tighten fan be happy that your not where i am, been frozen cold and snowing for three days good wrenching, hammer gone!!!!
Old Dec 26, 2009 | 8:03 AM
hayseed's Avatar
got it..that works.... thanks hammer
Old Dec 28, 2009 | 2:22 PM
SabrToothSqrl's Avatar
Default pump
"be sure to stop the motor.... first"
silvyman
Feb 28, 2011 11:14 AM
fourstop
Jan 4, 2011 8:41 PM
therewolf
Feb 18, 2009 11:46 AM
SuperTexan
Oct 29, 2008 4:10 PM
GirlInTruck
Mar 12, 2008 10:57 PM
