2004 Suburban won't start after fueling up.
Old Dec 14, 2014 | 10:14 AM
  #21
Originally Posted by Jmb
How do you fix this?
You can't; its hogwash.
-there is a sock filter on the end of the fuel pick-up; no way a single metal tab is going to block off the entire filter.
-the fuel cap seals the filler neck not the metal flapper.
great imagination though.
Old Oct 7, 2015 | 7:41 PM
  #22
Bradleyl's Avatar
i have exact same problem. Did u find out what the problem was?
Old Feb 25, 2022 | 3:59 PM
  #23
lauren p's Avatar
Default My metal flap is gone
Originally Posted by BMoTahoe
Remove the gas cap, look down the filling tube and see if that little metal flapper is gone. If it is, that's your problem. If it's not there, it's sitting in the bottom of your gas tank. When you fuel up, it's getting flushed down to where the fuel pump draws your fuel from. Same thing going on with my 07 Hoe. Check engine light is on and every now and then I'll get a TIGHTEN GAS CAP message. It'll show up as an emissions code because with that flapper gone, excess fumes are escaping. Let me know if you find it gone.
it is gone what kind of work needs to be done ? To fix this problem ?
Old Mar 5, 2023 | 10:23 PM
  #24
Ashley denn's Avatar
Default Flapper is gone
flapper is gone on mine. Have p0443 code and hard start after fueling
Old Mar 6, 2023 | 8:57 AM
  #25
p0443 is a purge solenoid fault. since you have a hard start after refueling...the purge is stuck open.
unplug the purge solenoid electrical connector connector. unplug the vacuum line from the purge solenoid. start the engine...if you feel vacuum at the solenoid....replace teh purge solenoid.
Old Mar 6, 2023 | 9:07 AM
  #26
t
Thanks for the reply I tried what you said and it doesn’t seem to be sucking. Any idea what else it could be
Old Mar 20, 2023 | 11:08 AM
  #27
Default Flapper gone and Evap code
did you figure it out have the same issue
Saad Alsofayan
Mar 6, 2023 9:56 AM
fdillardmd
Jan 29, 2013 4:04 PM
TLW64
Cobalt
Aug 23, 2010 1:58 PM
jayme0927
Feb 2, 2010 4:20 PM
atjohanssoj
Feb 9, 2007 9:05 PM
