2004 Z71 HVAC Low Pressure Valve Leaking
Old Sep 13, 2015 | 10:26 AM
Sergio Lisboa Machado's Avatar
Default 2004 Z71 HVAC Low Pressure Valve Leaking
Hi, recently I noticed the HVAC low pressure valve is leaking gas, I replaced the core of it but it hasn't solved the problem. I noticed that the screw were the schrader core fits is damaged, so I need to replace the complete valve. But I have a problem, I do not see how to remove it. I wold not like to buy a complete hose set as it is very big and can bem damaged when shipped to Brazil, were I live.
Does anyone knows if it is possible only to replace the valve.
Here are some images (from internet) that are the same I have in my car and the low pressure valve set that I already have at home to replace it.
Thank you for your help.
Attached Thumbnails 2004 Z71 HVAC Low Pressure Valve Leaking-lowpressureac.jpg   2004 Z71 HVAC Low Pressure Valve Leaking-img_0788.jpg   2004 Z71 HVAC Low Pressure Valve Leaking-leaking-valve-small.jpg
Barry A. Waters
Aug 17, 2019 11:12 AM
Jan 29, 2014 12:29 PM
MikeShirk
Dec 31, 2012 10:39 AM
mxphlipper
Jul 20, 2010 7:22 AM
