2005 Chevy Suburban Air Suspension System- battery draining when parked over night
Old Mar 1, 2017 | 10:55 AM
Veritas17's Avatar
Default 2005 Chevy Suburban Air Suspension System- battery draining when parked over night
I recently purchased replacement shocks for my 2005 Suburban – rear shocks along with a Dorman Compressor. Prior to replacing the shocks I had replaced the compressor a year ago. A month ago my battery died- I found I had a parasitic drain that I traced to the 30 Amp fuse RTD controlling the system. When I removed the fuse the battery did not drain, so I thought maybe the compressor was bad again- wiring etc so I received a new compressor under warranty and ordered Arnott shocks AS 2715- I installed them yesterday fired her up and it worked as it should. This morning battery is dead again. So what else in this system could be causing the parasitic drain? Like I stated, once I remove the 30 AMP RTD fuse for this system the battery does not die. So I have a new compressor and shocks- would you be able to point me in the right direction as to what other electronic issues in this circuit will cause the drain on the battery?
Old Jun 27, 2017 | 2:46 PM
Sean Thomson's Avatar
Ever find your answer? My battery keeps dying and think i have a similar issue.
