2005 engine change options?
Old Jun 6, 2019 | 9:08 PM
Richard Rockefeller's Avatar
Default 2005 engine change options?
I have a 2005 Suburban and am interested in replacing the engine. The current engine is a Z. How do I tell or can someone tell me what year engines can be used? What do I have to change to put in the bigger engine?
Old Jun 7, 2019 | 9:33 AM
oilcanhenry's Avatar
You might be able to jam a 6.0 liter U motor in it, but you'll likely need to put a stronger transmission in your vehicle as well. Probably many other things as well.
Old Jun 7, 2019 | 10:03 AM
Oldcat's Avatar
Don't put in any other engine than a Z. You will have nothing but trouble otherwise. The engine computer and fuel system is designed for flex fuel use. If you try using any other engine you will be plagued with driveability issues and check engine light. As far as what year engine to use, a good junkyard will be able to determine that. My 2 cents.
Old Jul 1, 2020 | 7:48 PM
did not see this until today, bought a T engine, the salvage yard said they are interchangeable. Now you are making me nervous!
PolicyPeddler
Jun 30, 2020 12:51 PM
BayAreaChevyGuy
Feb 25, 2015 11:33 PM
itrustno1
Jan 16, 2014 5:36 PM
92astro
Jan 4, 2009 10:05 PM
DAYMAN
Jul 9, 2007 7:12 AM
