2005 Suburban blowing hot air on driver side.
glfclbs -
How did the swap go and did it work?
Can you replace it from underneath the dash or is it a full dash removal?
My wife's 2004 suburban does the same thing and you can hear the actuator (i guess that's the noise) making some noise behind the dash most of the time. The fault to drive's side hot air though is intermittent.
Sorry, Just read my email. I tried a bunch of things. But if I recall the following worked for me.
1. Turn the car to "on" but don't start
2. Press the OFF button on the heater two times
3. Turn ignition OFF - wait 30 seconds
4. Turn ignition ON - but don't start
5. Wait 3 - minutes then start vehicle...
Thanks Beebe and DShepard!! I just did this and it worked!!!
I had my battery drained on my 2004 Tahoe by leaving a GPS plugged in for weeks, and didn't drive the truck. I recharged the battery outside the vehicle and when I put it back in and drove it, hot air was blowing out of the drivers side. Pass side was cold. Tried the sequence you suggested and it reset the control. Thank you very much!!!!
I wasnt sure how to start a new thread but i was hoping one of you could help me. My duel zone climate control in my 08 silverado seems to hav a mind of its own. it usually just blows barely cool air regardless of what it is set on. the passenger side usually just blows hot but has blown cool before. The actualtor on the driver side was replaced about a year ago but that didnt fix the problem. Today at the dealership the printout they gave me said bad hvac control. They want $763 to fix it. Are they talking about the digital controls under the radio or is there some kind of control module up under the dash? Either way this sounds high to me. Please advise. Thanks.
I have the same problem on my 2005 Suburban. I didn't want to deal with it, so I took it to a shop. They said they couldn't replicate the problem, so they couldn't do anything about it. I asked to have the actuator replaced, since that's what I would have started with had I done it myself. They replaced the actuator and did the reset procedure. It worked fine until today. . . I let me daughter use the Suburban and she mentioned the problem came up again.
There's an older TSB (Technical Service Bulletin) that covers the issue, 01-01-39-007. The wiring harness may have been miss-routed, causing strain on the connections, and consequently losing control functions. Just something to check before anyone goes and buys a new control module.
The actuator on my 2004 Suburban occasionally did the same thing.
I removed it, and took it apart. It is pretty simple inside, the important parts are a PCB with a thick film resistor and a copper spring contact that moves. There isn't anything to break and I saw no wear. Didn't seem to make much sense to replace something that didn't appear to be broken.
So I removed the copper spring contact and bent it a little more so it would put more pressure on the PCB, then redistributed the grease onto the moving parts.
Put it back together and no problems since.
Looks like a design/production problem where the contact doesn't put enough pressure on the PCB to maintain a good contact.
A/C blowing hot on drivers side only. Read everything on this bulletin board and tried everything. Nothing worked. So I took a suggestion to unplug the vent direction actuator while it was blowing cold in first 30 secs after starting truck. Now, I've got A/C. Guess ill plug it back in pre-winter. This is an insidious problem.
Just remove the actuator, carefully take it apart, bend the copper contact springs down so they put a little more pressure on the printed circuit board, redistribute the grease so everything that moves is covered, put it back together and it should work fine.
I have 2004 chevrolet avalanche with duel Ac/heat levers. with A C running and blowing cold gos TO HOT AIR On driver side. While the right side continues to blow cold air. If i stop and tour of the engine and restar it, then the Ac will blow cold on both Right and let sides, I went to a/c repair and he told to change the control panel, what I should to fix this problem?
I have tried these reset steps for my drivers side heat from the ac on my 2004 suburban but the problem continues. I have had a temp control in dash replaced ($450) by dealer and compressor ($900) at a shop. No luck so far. This all began after the dealer installed a new battery. Very frustrated. Great car with lots of life left but don't know what to try or who to trust.
Do you remember if you were able to resolve this issue and how you did it?
Hopefully you have resolved your problem by now, but in case not:
I'm having the same problem on a 2004 Suburban. Mine was intermittent a few times but has now failed on full hot. I have a set of shop manuals for our 2003 Avalanche, which also covers Suburbans. Probably the same for 2004.
There is a left side air temperature actuator and it is apparently going to full hot. I removed the "Insulator - Instrument Panel", which is on the passenger side so I could get to the actuator. Then I unplugged the connector from the actuator. The A/C on the drivers side would then work more or less normally. I assume that the actuator defaults to a neutral position if it doesn't get voltage, at least that is what it seems to do.
In my case I am suspecting one of the temperature sensors is the actual problem. My vehicle had been stolen and the gauge cluster and radio were taken. They have since been replaced with new units. I suspect there is either a damaged wire or a plug that is not fully seated. Could also be a defective part.
With a Scan Tool and the Shop Manual, it looks like you can monitor and control most of the A/C electronics so it should be possible to isolate the problem. I'll be working on that myself once I get a Scan Tool. Need on to maintain the vehicle anyway.
